Originally Posted by previously_boxsterz
Jake, what's your warranty on your motors?
Totally dependent on the engine and it's intended usage. My warranty is very specific, but not written in fine print and there are several responsibilities that the customer has during the warranty period.
Typically we rival the factory warranty on engines that are stock,
and that are installed on premises by our team. Engines that are designed for performance are only covered by a warranty while under our care and control, during the lab testing. Risk comes with mechanical manipulation and higher performance and thats just part of playing the power game. Always has and always will be.
I am working on an "extended warranty" program for the stock and performance engines, but the one mandate is that we must install the engine and give it the seal of approval (as well as the sub-systems supporting the engine) for any engine to be eligible.
One good thing about my program is no break in period. All engines are dyno tested in my lab and ran for a minimum of 12 hours, so you install it and drive it as hard as you want immediately after ensuring the installation job is correctly completed.
