Old 09-28-2008, 08:50 PM   #12
heyjae
Don't forget to check the oil cap. It might be the vacuum leak. Seriously, it may just be loose.
But based on your description, (at least on my S) there is a thin tube that goes from the intake manifold to the area behind the air box. I believe it attaches to the fuel pressure regulator. That tube simply slips over the fitting, so it could come loose very easily. It could be that.
I believe the vacuum tube to the EVAP system comes from the driver's side manifold as well.
2000 Boxster S
http://www.slipangle.com/images/ACSpeed_sig.jpg
heyjae is offline   Reply With Quote
