UPDATE- I got the codes.
P1128 / P1130
took car out for a drive - maybe went 15-20 miles... it was very hot outside, maybe 90degrees... no reallyhard driving.
i was a mile from home and noticed the check engine light was on. i have no idea when it popped on, i just know when i noticed it.
the car is running exactly the same as it did the last few days. no weird noises, no sounds, no nothing. i pulled over a hundred yards from home, stopped car, pulled out the key, let it sit for a few seconds, then started it back up - everything seemed normal. the CEL did not go away.
it's still there. is there any way I can easily figure out WHAT CEL code this is w/out goign to the dealer?
i don't want to drive it if it is something really really bad, but the nearest dealer is a good 40-50 miles away.
is driving it with the light on asking for something catastrophic / $$$ to go wrong?
any suggestions? thank you. this is a bummer in that I JUST got the car, but I'm optimistic that it's osmething not that bad. the car drove fine, made no weird noises...etc...
or is a CEL going on a big big red flag that the car is about to detonate?
should I run out and get that extended warranty now??
