Old 09-25-2008, 09:44 AM   #15
23109VC
so the brembo rotors are as good as OEM or better?
if I order those, plus the Hawk pads that tire rack has - i can just order ALL the stuff I need in one shot.
rotors, pads, and my tires.
although I'm not sure if tire rack sells the sensors or other little parts i might need for a brake job.... my wear light came on and someone said if the light comes on youneed to redo the sensors..
can I resuse all the other components..or are there any little pieces/parts I need to order along with rotors/pads?
I just went on the tirerack website and noted those Hawk HPS pads indicate they do NOT have cutout for the wear sensor...so does that mean you just leave the sensor off totally and forgoe using it? does the sensor light go off or stay lit up all the time?
if i want to retain teh wear sensor and have agood pad, what do you reocmmend..
maybe i'm just right back to OEM stuff.. pelican parts here i come
23109VC is offline   Reply With Quote
