Old 09-23-2008, 11:23 AM   #3
bonvita1973
Originally Posted by Tool Pants
This is a problem with 1997s. The mounting studs for the transmission go into sheet metal which flexes. I once saw a car where the transmission was on an angle because the sheet metal was bent. I could not even get to the top nuts to remove the transmission because the sheet metal was so bent.
My local dealership mechanics send the car out to a body shop to have the mounting area reinforced. I have never see the work done so I do not know how it is done.
If you have this done then see if you can take some pictures.
The body shop that the local porsche dealer sent mind to has never done this before, so they are waiting to hear from porsche reps on how they could fix the problem. yeah for sure will take some pics, if they ever fix it
bonvita1973 is offline   Reply With Quote
