Old 09-19-2008, 07:54 PM   #11
JackG
Originally Posted by Lil bastard
It's a falacy that more power requires bigger brakes.
Blanket statements like that are rarely true. In the Boxster's case, the brakes are already about as good as they get for its normal performance use, like DE or AX.
However, it's a fact that more horsepower on the track will provide higher entry speeds into the corners. With higher entry speeds, you will need more braking to haul the car down to the speed the corner requires. Even if you brake earlier, you'll still be requiring the brakes to absorb more energy. If they are already near their limits, adding more horsepower *will* overcome your brake's capabilities. Brake fade will result.
In that case, it would be a trueism that "More power requires bigger brakes."
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
