Old 03-29-2005, 06:25 PM   #7
Lux
Originally Posted by Perfectlap
which tires did you wear out in only 10K miles? wow, that's way less than a year's driving for me.
I have Yoko AVS Sports. I probably could've gone a few more miles but with the rain I was seeing at the time it was getting dangerous. Regardless, it'd be pretty much the same for all high perf tires. All of you getting 15K or so out of your tires, make sure that you check the inside tread as the outside can look fine. Tires are something you don't want to penny pinch.
I'd recommend swapping the tires side to side every 5K miles for max mileage. If you have directional tires, then that means having them unmounted and then remounted/balanced.
Lux is offline   Reply With Quote
