Old 09-18-2008, 11:13 AM   #13
Stroked & Blown
Originally Posted by blue2000s
Definitely yes, the base (big black plastic part) has the same pivot locations between the 9x6 and 9x7. The difference is always in the shifter itself.
The bases are a little different, the 9x7 has an additional screw-down point for something in the 9x7 console, but it doesn't interfere with anything on the 9x6.
Just to avoid confusion, I'll state again, there is a stock 9x7 shifter and a 9x7 short shifter, two different assemblies.
The 9x7 comes stock with only a slightly shorter shifter than the stock 9x6. It's about half way between the B&M and the stock 9x6. If you put a B&M in the 9x7, you will definitely get shorter shifts.
The EVO extension probably works with the 9x7 too, but you'd have to ask them, I don't know how long it is. By lengthening the lever arm at the bottom of the shifter, it shortens throws.
Right....So is a B&M in a 9x7 is essentialy the same as a B&M in a 986 assembly?
Worthwile options seem to be:
B&M / knockoff in stock 986 housing $50 - $200 (short but notchy)
987 assembly $160 (Smooth & slightly shorter than stock, easy to install)
987 SS assembly $??? (can't find prices)
987 assembly w/ Evo extension $360 (short & smooth)
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
