Old 09-18-2008, 10:38 AM   #11
blue2000s
Porscheectomy
Originally Posted by Stroked & Blown
So, does that mean a 9x7 assembly with a 986 B&M SSK is actually the same throw as installing the B&M on the stock assy? i.e. Most of the benefit to the 9x7 is in the teal colored plastic part which is replaced with the B&M(?).
Definitely yes, the base (big black plastic part) has the same pivot locations between the 9x6 and 9x7. The difference is always in the shifter itself.
The bases are a little different, the 9x7 has an additional screw-down point for something in the 9x7 console, but it doesn't interfere with anything on the 9x6.
Under that assumption, to get an even shorter throw with the 9x7 the only option is the Evo extension? Does the Evo ShiftLink shorten up shifts, or just make them more precise?
Just to avoid confusion, I'll state again, there is a stock 9x7 shifter and a 9x7 short shifter, two different assemblies.
The 9x7 comes stock with only a slightly shorter shifter than the stock 9x6. It's about half way between the B&M and the stock 9x6. If you put a B&M in the 9x7, you will definitely get shorter shifts.
The EVO extension probably works with the 9x7 too, but you'd have to ask them, I don't know how long it is. By lengthening the lever arm at the bottom of the shifter, it shortens throws.
