Old 09-17-2008, 09:01 AM   #11
blue2000s
Porscheectomy
Originally Posted by sb01box
if my question is redundant, please accept my apology.
I'm considering upgrading the shifter unit of my 01 boxster mainly to replace the plastic fastener of the main shift cable with aluminum/steel unit (EVO or Schnell). at the same time change to a shorter throw.
in reading discussion threeads here and at other forums, it seems that most aftermarket units just extend the bottom part of the shifter rather than 997 short shifter which moves the pivot point higher while maintaining the shifter to linkage position inline with the cable. to me, it seems that the 997 short shifter is a better solution and prevents unwanted bending of the cable and possible drag on the tray and carpet under the shifter. (if in error forgive me, no real hands on, just reading and pictures)
if my assumption is correct then my question is "why the aftermarket mfgs do not duplicate the mechanical dimension of the 997 ss?" 25% versus 35% reduction?
thanks in advance
tad
All short shifters other than the "swift shift kit" from Evolution motorsports move the pivot point up. To the best that I can tell, the B&M, clones, and 9x6 factory short shifters all have the same geometry. The Schnell is a little shorter on the linkage side and probably doesn't move the fulcrum as far from stock as the others. None have problems with the pivot point getting too close to the floor.
From the pictures I've seen, the factory 9x7 short shifter also uses the same geometry as B&M, but uses a plastic housing rather than the aluminum 9x6 version.
Many of us have discovered that the standard shifter noted earlier provided on most 9x7 cars provides a nice, shorter shift without excessive notchiness and is the preferred alternative to the standard 9x6 shifter. This is not a short shift kit, it is standard on most of the newer models. This part also includes the shifter housing and the plastic cable ends, so you wouldn't need to buy the aluminum parts you talked about.
