Old 09-16-2008, 08:26 PM   #11
sb01box
if my question is redundant, please accept my apology.
I'm considering upgrading the shifter unit of my 01 boxster mainly to replace the plastic fastener of the main shift cable with aluminum/steel unit (EVO or Schnell). at the same time change to a shorter throw.
in reading discussion threeads here and at other forums, it seems that most aftermarket units just extend the bottom part of the shifter rather than 997 short shifter which moves the pivot point higher while maintaining the shifter to linkage position inline with the cable. to me, it seems that the 997 short shifter is a better solution and prevents unwanted bending of the cable and possible drag on the tray and carpet under the shifter. (if in error forgive me, no real hands on, just reading and pictures)
if my assumption is correct then my question is "why the aftermarket mfgs do not duplicate the mechanical dimension of the 997 ss?" 25% versus 35% reduction?
thanks in advance
tad
sb01box is offline   Reply With Quote
