Thread: Window Problem
Old 03-28-2005, 08:56 PM   #1
Dragon986
Post Window Problem
99 Boxster- Driver's window no longer lowers to allow to allow proper fit to the top when you pull open the door handle. With the door open, I can manually push it down the 3/16 inch needed to allow door & window to close properly against the top. When I then close the door, the window still raises automatically to snug itself against the top. Is there an adjustment to the window I can make myself or is it likely something inside the door has broken that is keeping the window from working properly?
Dragon986 is offline   Reply With Quote
