If you're talking about running R Compounds on the street, I'd be more concerned with accumulating too many heat cycles in them before before they wear. Those tires are designed to last a few track days, not several thousand miles with hundreds of heating cycles.
And yes, most compounds used in any dry performance tire do not work well when cold, hence the significant grip tradeoff when the temps come down.
Patrick
