See no reason force the washer fluid throught the system. So I would remove the screen from the reservoir and suck the fluid out to where the sensor is that you can see on the side. Then hook up the motive and do the usual.
What I would have done is had the guy suck out the reservoir right then, and fill it up with brake fluid. Then left it alone. But I'm not going to Porsche heaven.
