F.Y.I. there is a part no. if you remove the screws holding the gasket on the headlights..........it can't be ordered seperate from the headlight.
I needed to order some because the headlights gasket were fitted to the past car's fender they were on, leaving me with a small gap on mine. I fixed this by removing the gasket,getting a very very thin cloth towel,cutting it to fit between the headlight and the gasket and now they sealed everything up. The towel pushed out the gasket enough to close the gap between the headlight gasket and the fender. It may sound confusing but you will see what I'm talking about after you remove the gasket.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
