Water pump replaced
My water pump went (at the most unopportune time of course... long story, it involves trip to Germany, Nurburgring, 6 hrs of waiting, and a long drive home in a rental... ) so I have just had the water pump and thermostat replaced. Picked up today - warm day here (25'C) in Netherlands and car was running at temp with needle cutting through the "0" on 180. Seemed to swing a little above under load, but came back down. This is a little higher than previous - is thermostat likely to be set at different temp? Should I be concerned? (model 986, yr 2000).
BTW, for anyone contemplating a service at around 75,000 miles, suggest you throw a water pump in. I have heard some horror stories at this mileage now, and I am lucky I didn't do a head gasket.....
