When the lights go out is the music still playing, because that is what it sounds like you are saying, or does is completely lose power? Also, from experience if you cannot fix it yourself, like a fuse or a loose wire, it is cheaper to replace it either with a used unit with a new code, or an aftermarket unit. Repairs can sometimes cost more than the unit is worth if it is an internal problem. The good thing is that it sounds like a loose wire behind the unit, either the power, remote, or illumination wire which may be easy to fix.
