Old 09-11-2008, 05:14 AM   #1
chitowndad
So sorry that it isn't working.
One last thing that I would try is to reroute the ground from the Avic to another source instead of the thick brown wire on the harness. If I understand ground loop issues correctly, which I'm not fully sure that I do, the amp and the head unit are sharing the ground and that needs to be seperate. Try running the Avic ground to another source. Simply connect a new wire and run that to anything metal - try a few different places. This lets the amp keep the original ground source which actually ends up connected to the frame behind the drivers headlight (pull back the carpet and you'll see).
-Steve
2001 Boxster S
Desnorkled
Pioneer Avic D3
JL Audio 6.5 inch subs (in the door)
Pyramid 4 channel amp
chitowndad is offline   Reply With Quote
