Old 03-28-2005, 01:55 PM   #1
Ronzi
Ronzi's Avatar
There is a switch in the area of the luggage compartment latch. You can actually reach it by sticking your finger in the latch opening in the plastic trim, towards the left (driver) side of the latch. The switch is actuated by a little spring loaded plastic peg.
Push that a couple of times and the light may come on.
I had the same problem, no light, bulb good, no fuse problems, etc.
Fiddling with that switch solved it.
Ronzi is offline   Reply With Quote
