convertible top problem
i have a 98 boxster. the plastic cover where the top latches to was loose.when i took the cover off i discovered that the threaded nuts inside the frame had broken into pieces.now there is no way to secure the cover so it just hangs from the wires when the top is down.has this happened to anyone? if so how did you go about fixing it.
