Installation isn't really "simple." It requires some tiny screwdrivers, lying upside down on your seat with your feet in the air, and removing bits of your AC ventilation to get to the cheap plastic part that needs to be replaced.
Don't let this scare you off from trying to fix it yourself though. Just know it's not as easy as replacing a rocker switch on your dash, which is a 1 on the 1-10 difficulty scale.
I'd give the ignition switch replacement about a 5.
