Old 09-08-2008, 11:27 AM   #2
Lil bastard
Lil bastard's Avatar
The Motronic 7.2 DME Diagnostics manual lists a number of possible causes for P1411 - Secondary air injection system, bank 2.
  • A bad secondary air injection pump
    restricted air supply lines
    electronic changeover valve not functioning
    air changeover valve not functioning
    vacuum leaks
    wiring harness
    relay
    DME control module
It also calls for a testing procedure using the PIWIS or PST2 tester and calls for specific air temperature and air mass values.
I suspect that since it's isolated to Bank 2, it's probably vacuum leaks or the MAF, at least that's where I'd start. The other causes call for replacement of components and need the tester to isolate them.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
