Originally Posted by FrayAdjacent
I'd suggest checking and cleaning the MAF again. This time, with something specifically made for it. Check your filter, too. A clogged filter might hinder responsiveness.
All filters are new OEM recently replaced. I'll try to clean the MAF sensor with MAF Sensor cleaner. Is there a general rule for how much to spray onto the sensor? Should I soak it enough to actually drip? I'd assume it should not be wiped, etc. only sprayed.
