Old 09-03-2008, 10:42 PM   #3
Lordblood
Originally Posted by Rareair
Your missing the rear strut brace? It was never factory installed, it's an aftermarketr piece. So it can't be missing, it was just never installed.
From your parts list, seems you want to add Carbon look pieces to the exterior. It should look fine. I've seen other dark colored cars (ie...Black) with Carbon and it blends in fine. As long as the Dbl weave fabric is layed properly, and with help from some sunlight, you'll be able to achieve the look you're after.
Ah I did not know the strut brace was an aftermarket piece, you can see the whole engine from the underside of the car and I thought there would be a flat underbody or at least something there to keep the engine inside.
And yes, you are right, I just want to add to the cosmetic look. Honestly the 986 box doesn't give off the sporty feel that the 987, or similar cars in the class tend to give off, so I'm trying to help it along some.
Lordblood is offline   Reply With Quote
