Thread: Hardtop Help
Old 09-03-2008, 05:14 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
Your going to have to adjust the top. Pull off the plastic cover on the inside of the top and you will see 5 bolts, that take a 5mm allen wrench. Loosen them, and then you should be able to get the top on. Once the top is one you will probably have to repeat this process to get a good fit.
