Thread: Hardtop Help
Old 09-02-2008, 09:34 PM   #2
greesedc
Lightbulb spin lock adjustment
Mike:
Had the same problem with my recently acquired hardtop. Since my car is in the garage on the lift at the moment, I can't tell you what size, but there are 2 or 3 bolts inside the hardtop behind the pop off cover that hold the locking lever in place. I loosened them slightly and then turned the handle until the pin virtually adjusted itself and locked into position. Tightened the bolts with the top locked and had no trouble since. I haven't leak tested, but the seal looks like it is compressed enought to do the job.
Maybe someone with the real answer can add something I did not self teach myself.
Don
'01 Boxster
greesedc is offline   Reply With Quote
