Originally Posted by Pokerstar
Thanks, good suggestion
You can also go over to cannell.co.uk and download the diags for the 986 model. The Durametric tool allows for graphing of actual values -- check the upstream/downstream O2 sensor waveforms to see if they're working OK. Also check fuel trim (adaptation) as this is the big indicator of drivability problems in all gasoline cars. Good luck.
Regards,
paul...
