Thread: Kirk's Ride...
Old 09-02-2008, 09:40 AM   #11
Kirk
Dash Speaker Install
I spent some of this weekend working on the stereo system. Here are some pictures of my solution for the dash speakers. Now I'm not much of a custom stereo fabricator. The last time I built a box and amp rack was 1996 and I've NEVER done vinyl work before. So consider this a work in process. I'm not sure I like it this way, so I'm open to constructive feedback. My SO says it looks messy where I cut the mounting tabs off the 4" speaker. I need to do something (some kind of trim) around the edge of the 4" speaker to clean it up a bit.
Here are the speakers I installed. The stock OEM speakers are on top and the new speakers are on the bottom. You can readily see why I needed a baffle to give me more clearance under the speakers. The magnet on the 4" speaker is HUGE compared to OEM and I needed a lot more space to make it fit. It fits fine with a 1/2" lift from the baffle and top mounting.
Here are the speakers installed. The Polk tweeter has a base where you can aim it a bit. I built a "pod" for it to sit on so that I could aim it directly into the cabin rather than up at the windshield. I think this looks a little funny, so I may not keep it. I'm trying to go for the best sound though. Please note that this will NOT work for most setups. The driver's side speaker will be too "bright" with it so close to your ear compared to the passenger side speaker. In my system I will be using time delay on the driver's side speaker to compensate and to put it in phase alignment with the passenger side speaker, so I'll be able to get away with this.
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
