I go back in with a factory hose clamp
Stock spring clamp is on the left, factory hose clamp on the right! This hose clamp does NOT need 400lb. ft. of torque on it. Just snug. You'll find that trying to put the spring clamp back on with your arms fully extended from the wheel well will prove to be nearly impossible (unless you manage to locate the proper locking pliers that hold CLOSED on the clamp) I find it MUCH easier to stick a 7mm nut driver up there to a regular hose clamp and MOVE ON!
Here is the factory part number for the clamp I used. It is a "fluid" hose clamp meant for BoxsterS 3rd radiator hoses. Feel free to use any hose clamp you feel comfortable with. I choose factory parts as much as possible in my builds/repairs.
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
