Thanks for the suggestions. I will be back at it on Monday got to work all weekend. Will try the Vacume leak test with the Carb. spray and I don't think I did the Mas Sensor test drive correct. I unhooked the Mas sensor but I did not unhook the battery before I took the test drive with the Mas sensor unhooked. Should I unhook the battery before I test drive it?
Daniel
