Donjuan143,
I see by your profile your from Bahrain, the riviera of the Persian Gulf. Obviously having the air working is a must. You said you had a CEL and the dealership could diagnose the problem? Does the service department have the right tools? They should have easily told you whats wrong with your car.
If you engine couldn't handle the load of the A/C, the mechanics should have done a compression check. With the A/C on do you get cool air? Your compressor might be on the way out. Make sure the mechanics know what their doing.
