As Bmwm750 pointed out it is a dual mass, aka dual mess flywheel. None of the dealerships in my area will play around with it, just like they will not resurface brake rotors. I only know 1 independent shop that will consider having it resurfaced, but you get the warning if it does not work properly....
And speaking of messes. Here is the clutch disc from an autocross champion. And yes, he also needed a new flywheel.
