Originally Posted by Tool Pants
The clutch disc is held together with rivets. Once the friction material is worn out the rivets can contact the metal surface of the flywheel and/or pressure plate and score the metal surface.
If the pressure plate gets scored it does not matter, because a clutch kit included a new pressure plate. If the flywheel gets score, then it is resurfaced or replaced. Some shops will not attempt to have a flywheel resurfaced. That means a new flywheel and retail is $900.
You might want to do a clutch replacement now.
Absolutely great advice! I didn't even think of that, good call !
