Old 08-24-2008, 06:22 AM   #5
Bob O
Originally Posted by Kirk
Bob, I've got several pieces of 2X4 wood cut to about 8" in length. My car is so low that I have to drive each end up onto these 2X4's to get it high enough to get the jack under it. Once I've got it on jack stands I can raise it up higher by simply placing one of these 2X4 pieces on top of the jack pad and use that to then jack up the car (the 2X4 is sandwiched between the jack pad and the car). It should give you the extra lift you need to get the jack stands up higher so that you can fit under the car.
Kirk
Kirk: I thought about doing that, but I was visiting with the indy about another car anyway and asked him about using his lift. When he said ok I didn't give it any more consideration. Your procedure would work fine, but if I can stand up to work on it.. whoooooo hooooooo...
uhhhh Rick,, in 20 years I'll be 78... don't think so! But thanks for the offer
79 911SC Targa.. gone but not forgotten
2001 Boxster Black/Savanah Beige
RoW M030 suspension
7/15 mm spacers
Deambered
Desnorked
SS door sills
Debadged
Clear tails
Technobrace
Technobra
I'll never own another black car!
Bob O is offline   Reply With Quote
