Originally Posted by saiful
My power top stopped working properly. The passenger side stopped engaging. I was able to put the top up some how... but it's not up properly. I don't have the specs, but are there two separate motors to control the top? Because I would best describe this as the passenger side motor is not working. Is this an easy fix? How much damage am I looking at if I take this to the dealer? Thanks.
The way you describe the problem I'm going to guess you have a 986. (Always include your year) It sounds as if you have snapped a roof transmission cable(s). This is pretty common on older Boxsters. If you have not bent the clamshell too bad a dealership will nick you for about $1500.00 to fix this. It is not for the everyday DIY. If the clamshell is severely bent there could be a bodyshop involved. It happened to me on my '97, "ouch". That's where the estimate came from! Good Luck!!
"97 Boxster" Guards Red, Coppell, TX 36,500 miles
2010 Mazda CX-7 AWD, Turbo, Grand Touring
