Old 03-23-2005, 11:53 PM   #1
JP-s-in st. louis
A few months ago a Guards RED 928 in some porsche mag was using one made by e-charger. It was in cali. I do not remember much about it though.
My question is since the boxster is already has such high compression is this ok or not. This systemwould give it very low boost. From what I have read these systems have two speeds ON and OFF. Now I was thinking that you may be able to tap into the "drive by wire" system on cars made after 2000 to control the speed. I will also reserch the 928 that was in the mag. and contact the owner for their input. This is somthing I have toyed with and as soon as I investigate more or get the balls to try it I will let you know.
JP-s-in st. louis is offline   Reply With Quote
