Old 08-06-2008, 08:19 AM   #10
RandallNeighbour
Kevin, it's time to pry more knowledge out of your head about these coilovers. I know this will take some time, but if you can answer my questions once here with these pics, you will not be badgered by other forum members in the future
Here we go.
In this first photo, we see all the tools and bushings sent with the coilovers. Please explain what each of them do, how they're used, why I have six of one tool, two of another, only six rubber bushings, do the bushings go on the fronts or the rears, do the bushings go between the tops of the strut mounting plate and body or under then nut inside the trunk area, etc. There were ZERO instructions on this in the box.
In this second photo, we have a shot of the back strut. Please explain which direction I should move the strut... toward A or B? One other question... is the B side the outside or the inside?
In this last photo, we have a shot of the front strut. This one will be more complicated to explain, but I have questions as well. Is the A or B side the outside? Do I loosen the bolts and move the strut toward A or B? Where should the bolts C or D reside when they're in the right place?
I've barely got enough cash scraped together to get them installed right the first time, so I don't want to be forced to remove them for any reason to fix something I didn't get right. What I will do is to do the setup mods you mentioned earlier after a response and photograph them and post pics of the mod for your approval if that's ok with you.
