I have the same problem and plan to change it soon. The "Bentley" 986 repair manual has a detailed section on how to replace the washer motor. The washer fluid container is located behind the LF wheel within the fender arch (behind the fender cover near the bulkhead/firewall. You have to remove the wheel and arch cover to access the fluid container which holds the little motor. You have to remove the washer fluid before you attemt to remove the container itself. Once removed, you can re/re the little motor - replacing is reverse of removal.
