Old 08-03-2008, 12:59 PM   #1
j.fro
Rennzenn
j.fro's Avatar
Internal muffler hack how-to!
A lot of Boxster owners, including me, are not happy with the stock sound of the 986 exhaust. It’s just too quiet. We know the sound is in there, and we want some more of it. The factory addressed this issue with the PSE system, but that’s very expensive, and it adds weight to an already heavy component. After having a look at the PSE system and figuring out how it works, it became obvious that the same enhanced sound (without the on/off valving) could be easily built into a stock muffler. In the Boxster muffler there are two chambers on the left, two on the right, and one in the center that is largely unused. Exhaust gasses enter through either side and expand into the second chamber, as they run into exhaust gasses entering from the opposite side. I believe this center “collision” is responsible for quieting much of the resonance. After expanding into the second chambers, gasses travel through a pipe into the outer chamber on the opposite sides. They then follow pipes back towards the center and flow out on the opposite sides from which they entered. Essentially, the exhaust gasses from each side make symmetrical loops. To get greater sound, the PSE and this internal modification straighten out the flow by bypassing the two intermediate chambers. The PSE has pipes connecting to the central pipe in both of the outer chambers. The pipes go through the back of the muffler, wrap around it, and plumb into the two tailpipes. Pedro’s popular exhaust mod does essentially the same thing, but begins outside of the muffler. For the internal hack, we’re going to cut the central exhaust pipe inside of the first muffler chambers. This will allow gasses to expand into those first chambers and exit through the tail pipes on the same side that they entered, bypassing the loop and the intermediate exhaust chambers.
Cutting the pipe is tricky because you don’t have a lot of room to work. Fortunately, it can be done with the muffler on the car. Start by removing the rear bumper cover and the heat shielding around the ends of the muffler. Next, remove the elbows connecting the cats to the muffler. Peek inside the muffler. You can see straight through it! What you’re going to be doing is making cuts in the pipe, just inside the external walls of the muffler. Before you do this, think about how much more sound you want. The larger you make the openings, the more sound you’ll get…but with more sound will come proportionately increased resonance. I suggest two tools for making the cuts. The first is a Dremel or similar rotary tool with a flex extension attached. The flex extension is small enough to be fully inserted into the exhaust pipe. Along with this, you’ll need the Dremel EZ Lock 1.5” cutting wheel. These are stout enough to cut into the stainless steel on your exhaust. With the Dremel tool, you’ll be able to make horizontal cuts across the exhaust pipe. To get minimal increases, cut three or four slits on both the front and rear sides of the pipe. For those wanting more sound, you’ll need to cut more material from the pipe. This is easiest with an air hammer and a long chisel bit. After making a horizontal cut in the pipe with the Dremel, use the air chisel to cut along the pipe, creating a square opening. This can be bent into the pipe to direct flow into the exterior muffler chambers. Again, the bigger you go, the more sound you’ll get. Do your best to keep the size of the openings similar on each end of the muffler, as you want to keep flow on each side equalized. When you’ve got the openings you want, put it all back together and fire her up. Nice sound, eh?
So here comes the sales pitch: I'll do the hack for $100. All you've got to do is get the car (or just the muffler) to my place and then away when it's done. I'm Palmyra, Virginia, just east of Charlottesville. For kicks, have a look at my website at www.rennzenn.com
Cheers
Jeffrey
