I did the same yesterday. Pre-heat with an hair dryer and use dental floss and saw under the emblem to cut the neoprene type glue. Did remote about all of the glue by finger and uses Bug & Tar remover spray to help. Did put some wax and install the new emblem. Helping thing, if you are replacing the old emblem by exactly the same new one, you should see the letters on the car as peint color is not the same. That will help you to stick the new one exactly at the same place.
Bonne chance et utilise beaucoup d'huile de bras mais c'est facile et le résultat fascinant!
Thierry
