I just used some rubbing alcohol and a sponge (one that also has the scrubbing thing on the other side).
I poured a bit of alcohol on the sponge and lets it soak into the stickers. The bottom one was easy, you could move the sponge around to rub the alcohol in. But the sticker on the vanity mirror, when I moved the sponge it took bits of the sticker off which made it harder to peel off.
But yeah, once the alcohol has been on the sticker for a couple min, you can start peeling the side off and if your careful you can get the whole sticker off in one piece.
There will be a bit of discoloration up close. But its cheap and it looks pretty good
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
