Old 07-26-2008, 04:27 AM   #1
E Kaplan
water under seat solved!
For readers of this forum who notice wet carpet and have open drains, here is another item to check. If you open the convertible top half way, you will see fabric from the top snaps into 2 plastic holders. This allows proper flow of water from the top to each of the rear drains. If the fabric is not inserted correctly, water will flow into the padding behind the carpet behind the driver and passager seat and eventually under each seat. This was the problem I was having. No more problems after simply snapping the top back into proper position. Thought people with wet carpets might be interested.
Eric K
E Kaplan is offline   Reply With Quote
