I've narrowed down my problem to a couple things I guess... Im pretty sure the car needs to be lifted and the center (the one closest to the passenger side of the battery) drain point needs to be cleaned. I included a picture of where water goes when its poured down that drain point. Also, while i was doing this, some more water got into the cabin, I have a picture of that and some weird tube. I dunno what it does, I doubt it has anything to do with my problem, but maybe im wrong. Well, any help would be much appreciated.
(water spot and random pipe I found)
(the 3 places water comes out, I believe its supposed to come mainly from the center one which is also the one that flowed the poorest)
"If you feel like you're under control, you're just not going fast enough."
-Mario Andretti (cliche!)
2002 Boxster S 6 Speed (Ocean Blue/Savannah)
-De-Snorkled, Porsche (B&M) Short Shifter, EVO Shift Linkage
-H7 HID Upgrade
-Rennwerke Maintained
1998 Bouvier (Brindle)
http://inlinethumb03.webshots.com/42...425x425Q85.jpg
