Old 07-19-2008, 01:30 PM   #12
Kirk
Originally Posted by insite
in addition, the OEM firewall / strut tower braces are designed for tensile / compression load. loading them in the middle is not smart.
Why is it not smart? Under tensile or compressive forces the middle brace simply holds the two OEM braces together to keep them working as one unit and reduce flex or movement. The middle brace certainly wouldn't decrease the tensile or compressive forces that the OEM braces can withstand. So I go back to the old mantra I had with the lower stress bar side braces - it can't hurt and can only help. The main load is still at the shock tower where the force is applied. Any flex or deflection from compressive forces would now be spread over the whole assembly and it should be stronger and more rigid as a result.
Kirk is offline   Reply With Quote
