Old 07-18-2008, 06:08 PM   #2
chitowndad
I'm 99% sure that the amp over heated because it's damn hot in the front trunk - I was cranking the amp for 1/2 hour+.
I read somewhere that I need to connect the blue switch wire from the radio to a relay then to the amp and fan switched connections...
I'll try again but I did try the following:
This is causing the issue, the fan is turning on the amp when it shouldn't
Amp always hot wire -> Fan hot wire
Amp switched wire / lead -> Fan negative
Fan always on:
Amp negative -> Fan negative
I'll try
Amp switch wire / lead -> Fan hot wire
Amp negative ->Fan negative
2001 Boxster S
Desnorkled
Pioneer Avic D3
JL Audio 6.5 inch subs (in the door)
Pyramid 4 channel amp
chitowndad is offline   Reply With Quote
