Old 07-17-2008, 08:38 PM   #4
ISUnorth
Originally Posted by tboyer
Check the water pump, a likely culprit, I've had two go bad with your exact symptom. In addition, your tank might be cracked and leaking through the trunk, check for under the carpets. Make sure your coolant cap's product number ends in 01 or better. The fan will run if needed, even after the car is turned off.
I checked and the cap number ends in .01
When I just looked the coolant level is a bit low in the reservior now but it is not leaking into the trunk. I had heard about the leaking tanks and checked that.
ISUnorth is offline   Reply With Quote
