Originally Posted by fragdude
On a side note, if you do/did buy the car and decided to change the clutch or when you do replace it, it would be a good idea to install an updated Rear Main Seal at that time. The part costs 10-20 dollars and should be close to 0 Labor
Have to disagree. If the current seal is good - don't mess with it. Seals often fail due to improper installation and you run this risk unecessarily if you swap the seal when it's not needed.
