Old 07-15-2008, 07:15 PM   #5
jhandy
Camber
Just a thought.....Would it not be correct in saying that the further you push out the wheels, the more camber you produce? I say this because after I put my 7mm spacers on I noticed that the inner border of the rear tires wear much faster.
Should I have the camber adjusted?
What is standard for off track driving? And how could you measure it correctly if you have spacers?
Thanks,
James
2002 S
jhandy is offline   Reply With Quote
