Old 07-15-2008, 03:35 PM   #3
rick3000
There Is No Substitute.
rick3000's Avatar
I've read into this, because have been considering doing it. The absolute best way to do it is to get the calipers powder coated, but that cost a lot. Most people don't remove the calipers and have no problems with that method. It will be better to remove them, but it isn't necessary, and won't make a huge difference. It will just be easier to paint if you remove them.
The clear coat is a good addition and I would do it, but it's effects are debatable. I have heard of some people using a few coats with great results, and others doing this and having it crack off.
It depends a lot on your driving, if you break really hard often the paint/clear coat is going to have to withstand a lot more than if your gentle. So the cracking/peeling/flaking depends on you more than the paint.
