Old 07-14-2008, 11:09 AM   #2
JackG
There's very little reason that the module wouldn't be good once it has dried out. Most modern PC board manufacturing processes use water soluble flux solution, and the boards are cleaned (after the soldering process) in what is basically a dishwasher with water!
The thing is that the dirty water may leave deposits on the board which can interfere with it's operation. Also, you may have some components, such as relays, which may be difficult to get dried out completely.
If it were mine, I'd get some canned PC board cleaner and spray it down on both sides, then bake it in the oven at 100 - 125 degrees to get it completely dried out.
Hope that helps!
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
